Categories PI SQL Client
Created on Aug 23, 2022
Add RTQP PI SQL support for parameter type cast
PI DAS (RTQP Engine) 2018 SP3 Patch 1 lacks support for type casting input parameters of a table valued function. For example. this simple example fails to create a table valued function: CREATE FUNCTION [MOMS].[fact].[getInstrumentOperationalDataStringOverload] ( @StartTimeIn String, @EndTimeIn String, @TimeStepIn String ) AS SELECT * FROM MOMS.fact.getInstrumentOperationalData( CAST(@StartTimeIn As DateTime) ,CAST(@EndTimeIn As DateTime) ,CAST(@TimeStepIn As TimePeriod) ) The following example fails in similar fashion: CREATE FUNCTION [MOMS].[fact].[getInstrumentOperationalDataStringOverload] ( @StartTimeIn String, @EndTimeIn String, @TimeStepIn String ) AS SELECT * FROM MOMS.fact.getInstrumentOperationalData( DateTime(@StartTime) DateTime(@EndTime) TimePeriod(@TimeStep) ) Error message: The table-valued function definition is not supported.
