Categories PI SQL Client
Created on Aug 23, 2022
Include overridden attributes of derived templates in Event Frame View with PI SQL DAS (RTQP)
When you create a template-specific event view, event frames based on derived templates are also returned. However, attributes which are overridden in the derived template return empty. This means more complicated queries using UNION ALL must be used. As a user, when I use a derived template with an overridden attribute, it is often because I need to change the way that attribute is calculated in a subset of cases. However, I still want to be able to create a view easily for all of this data. For example, I have a "Batch" template with "Pounds Produced". However, for a specific case, the "Pounds Produced" calculation needs to be different. I still want to easily be able to create an event view for all my batches.
  • SachaSTM
    Apr 27, 2026
    Hello, I see that this is an ongoing bug and it impacts a lot of users. We are using RTQP and facing the same problem. Extracting data from a parent template is a basic function and this should be addressed/patched with priority. It is the first query any client will try when using PI SQL Commander. We have some template hierarchy with over 20+ child templates and Union all of them is a trivial workaround but not what the product is meant to be used for.
  • MattBa
    May 20, 2024
    Yet another issue that will probably never get fixed. Two years plus on this one. It seems like incomplete product to me.
    Aug 23, 2022
    Any update on this?
    Aug 23, 2022
    Using RTQP we are also facing this - derived templates are returning null values for overriden attributes... really not good enough. Tech support's suggestion is to use UNION ALL for every query, for each derived template.......seems like a major bug to me that needs to be fixed ASAP.
  • MarkGoepel
    Aug 23, 2022
    We've hit this issue with Element Templates. Template inheritance is a powerful feature of AF, which prvides many benefits across the PI Platform. It is a pain that we have to treat the templates differently, even though it is a simple matter of for some element types the underlying tag in the control system is different across the different asset types. *No we are NOT going to mask the issue by moving the tagname override into the InstrumentTag... Can we please have this addressed with priority?
    Aug 23, 2022
    Hi, is this in the engineering plan to be corrected in the next version of RTQP? One of the major benefits of PI AF is template inheritance; the fact OSIsoft has a product that doesn't cater for this to me seems like a major oversight.
    Aug 23, 2022
    I found a workaround in the past, this was an issue with the PI OLEDB Enterprise provider also. The issue is the attribute has to be in the base template. So I created some hidden attributes in the base template just for reporting/SQL pointing on the original attribute. So these attributes don't get overriden and keep working in a query built on the base template.
