Complete PI Web API documentation
As a PI Web API user I want to know exactly what kind of Body Parameters (their defaults and description) are supported by PI Web API methods. The current sample requests are not sufficient because they do not describe the values for body parameter, though many parameters have unique restrictions. Here is an example of desired content: https://developers.jivesoftware.com/api/v3/cloud/rest/StreamEntity.html
    Aug 23, 2022
    We have received a lot of feedback on this. We are looking at on-line help with better samples of queries and responses. We are looking at some web frameworks for offering a live "Try It" feature for PI Web API. We are also looking at comprehensive search within the PI Web API help system.
    • GaryYegiazaryan
      Jan 19, 2024
      There used to be a Swagger specification, but it was removed from the documentation in PI Web API 2018 SP1 with no explanation as to why.
      It would help speed up development if we had a swagger or open API spec. The current documentation is not sufficient.
      https://docs.aveva.com/bundle/pi-web-api-reference/page/help/changelog/pi-web-api.html#:~:text=Removed%20OpenAPI/Swagger%20specification%20endpoint
    • zwhite
      Sep 14, 2022
      Here is another great example for api documentation. https://www.bitmex.com/api/explorer/
      Lists all the endpoints and the accepted operations per end point, and then will build a URL based on what ever operations are submitted.
      Aug 23, 2022
      An example of a good API: http://docs.winkapiv2.apiary.io/#reference/device/camera/get-camera 1. Has a hierarchical navigation (on the left) 2. It explains what the call is and what the parameters / attributes are 3. It give an example request in a lot of different ways: RAW (http), cURL, JAVA, javascript, node.js, Perl, Phyton, PHP, Ruby, Go, C#, VB, Groovy, Objective-C, Swift 4. It gives an example response 5. It allows you to run your a query against a simulated set of data 6. exportable (prefer to pdf for offline reading, but to a standard APIB or swagger is ok) Maybe the included swagger export will help - but that is another tool/client I need to now install learn - if you look at the link above - it almost includes all of my requirements already.
