The inability for PI Web API OMF to send data to multiple PI Systems is a significant limitation in both PI Adapters and PI Web API. To address this, either:
The PI Adapter egress configuration should allow specifying the target PI Server or collective, or
PI Web API should provide a dedicated OMF endpoint for each configured PI System.
The expected workflow is that multiple edge adapters could send data to a single PI Web API instance, which would then route the data to the appropriate downstream PI System.
Currently, each PI Adapter requires its own dedicated PI Web API instance, creating unnecessary complexity and infrastructure overhead. This limitation is a critical blocker for migrating from PI Interfaces to PI Adapters.
