Categories PI Web API
Created on Aug 23, 2022
Support Bearer Authentication with Channels in the Web API
No description provided
    Aug 23, 2022
    Thank you for your feedback. Unfortunately, this feature is not a priority at time, so I am setting the status to declined.
    Aug 23, 2022
    This limitation exist in the Mozilla websocket specification that all modern web browsers use. Other frameworks (e.g. .NET) support websockets authenticated with Bearer. You can get around the Mozilla websocket limitation by using a web proxy with header rewriting capabilities (e.g. nginx). You can then open the websocket from the browser and use the "Sec-WebSocket-Protocol" header with value "access_token {jwt}​". The web proxy should then append a header for Authorize Bearer {jwt} and remove the "Sec-WebSocket-Protocol" header before passing the request to PIWebAPI. It requires some configuration, but will help you out if you really need this authentication option.
