Categories PI Web API
Created on Aug 23, 2022
Allow inputs to be defined for calls to stream values
The stream endpoints should allow passing input attributes/values if the attribute's Data Reference supports it (refer to the AFDataReference.GetValues method in the AF SDK). For example this could look something like: .../stream/{WebId}/recorded?input.myInput1=myValue1&input.myInput2=myValue2 One strong use-case for this would be an attribute configured as a Table Lookup Data Reference that returns a time series but allows a parameter to be defined.
    Aug 23, 2022
    Thank you for your feedback. Unfortunately, this feature is not a priority at time, so I am setting the status to declined.
