Categories Functions
Created on Aug 16, 2022
Support named ranges to avoid issue KB01369
Excel places named ranges in formulas when a cell has a named range (instead of cell references). Excel formulas become more readable this way. Datalink should support defined named ranges too. Editing a Datalink array formula directly in Excel and replacing cell references with named ranges in works already. But Datalink pop-up dialogs can only use cell references. With named range support for parameters of Datalink formulas no workbook and worksheet named are added to the formula anymore avoiding the issue of KB01369.
    Jun 3, 2025
    At this time, this item is not currently scheduled for a release of PI DataLink. If this changes, this item will be updated to reflect the current status.
  • Brent Bregenzer
    Jul 9, 2026
    Now that DataLink supports dynamic arrays, can you please expand this request to include full support for the spill range operator (#)? See article below for fuller details of both use cases:
    Use dynamic array as input to DataLink function
  • tinklerj
    Aug 16, 2022
    "Editing... directly... replacing cell references with named ranges works already" - but as soon as you recalculate/resize, all the named ranges in the formula are replaced by cell references again.
    Aug 16, 2022
    In response to Jeremy Tinkler, ""Editing... directly... replacing cell r..." older versions didn't do this, some where around 2017 they decided to "reinterpret" your cell references and overwrite your formula where older datalinks did not. For instance, I am dealing with this nasty "Microsoft is Waiting on OLE issue" using Calculated Data to find a Maximum. However, if i delete the absolute reference in the formula bar and CTL-SHIFT-ENTER to maintain the array I can query all the data I want without getting the error. If I click the range of data in the Calculated Data Tab, EVERY SINGLE ENTRY makes me click ok, and thats a pain on 47 tags. Not going to deal with that for 1000 metering tags which is why I find more and more reasons to use C# and AF SDK so I never have to use datalink for anything.   Long story short, the Cell references in the formula bar are over written by the calculated data module with the cellular range, but for some reason it seems to magically work again without throwing the OLE issue. I wish the module would not over write our manually created formula like the old days. I can't see why it is a "feature" to overwrite the user hard coded excel arrays.
    Aug 16, 2022
    Aug 16, 2022
    Aug 16, 2022
    Aug 16, 2022
    Aug 16, 2022
    Aug 16, 2022
    Aug 16, 2022
    Aug 16, 2022
    Customer would like to enter a dynamic range of tag names in the Data Item field for a Sampled Data function in DataLink. Currently, the Data Item field only takes a single tag or a specified Excel range of cells. Customer would like to add and remove tag names and use a dynamic range of tag names in the Data Item field.
    Aug 16, 2022
    As tinklerj mentions, it is possible enter a named range in the cell directly, but since Datalink replaces it immediately, it defeats the purpose of a named range. The usefulness of named ranges is that they can be made to be dynamic to change size depending on how many points there are etc.
