Categories Task Pane
Created on Aug 16, 2022
Add the ability to multi-select and move display columns in Asset Filter Search, Explore Events, and Compare Events
Currently, only a single item can be selected and moved (or deleted) in the "Attributes to display" list in Asset Filter Search. An analagous behavior exists in the "Columns to display" list in Explore Events, and Compare Events. For each of these list, the ability to be able to multi-select items and move or delete them would be a nice feature. Note: This was previously Enhancement 27051OSI8
    Aug 16, 2022
    Hello Everyone, While we appreciate the community’s interest in this suggestion, we have decided to decline this item in favor of other high-priority work the product needs. Thank you for your feedback, and please continue sharing suggestions for improving PI DataLink for you! Thanks, Victor Zhang OSIsoft, Product Manager
    Aug 16, 2022
    Select All and Selecting Parent should select all Children as well.
    Aug 16, 2022
    One possible workaround for this is: 1) Bring in the event frames normally (not selecting any child attributes). 2) Inside of the excel formula replace the attributes string with the string "{ALL}" 3) Resize the excel array accordingly using "Shift+Ctrl+Enter" and "Ctrl+Enter"
    Aug 16, 2022
    When we use Datalink to select the child attributes, you have to select them one at a time. Being able to select several at once would be nice.
