Allow Tag Template Triggers to trigger on blank placeholders
Currently, Batch Interface Framework interfaces implement tag template triggers that can trigger whenever a placeholder has any value. These interfaces should also support triggering when a placeholder does not have a value. For example, our SISBatch data source has separate columns for Operation and Phase information. We would like to record the value of the [DESCRIPT] column in a tag only for non-phase batch events (i.e. trigger the tag template only when the [PHASE] placeholder is blank).
    • Monica Rattaggi GSK
      Mar 21, 2025
      Thank you Ellery for the clarification.
    • Admin
      Ellery Murdock
      Mar 20, 2025
      This functionality is available in the latest version of EMDVB, 5.1.10.
      It is briefly mentioned in the following documentation link:
      https://docs.aveva.com/bundle/pi-interface-for-emerson-deltav-batch/page/1269245.html
      Mar 7, 2025
      Is this functionality available in EMDVB Rev. 5.1.10.7?
      The workaround to avoid filter on blank placeholders is quite complicated in our environment.
      Regards, Monica
    • Tim Proeber
      Jun 6, 2024
      We found out that there is an undocumented [BLANKPLACEHOLDER] that works. It is documented in the FactoryTalk Batch manual.
      Regards,
      Tim Proeber
      Sanford | Timohty.Proeber@pfizer.com
      For Urgent Issues or requests please contact Global Historian Team dl-gbl-mfg-historian-group@pfizer.com
      [cid:image001.png@01DAB82E.F650FC80]
    • Admin
      Ellery Murdock
      Jun 6, 2024
      This is now planned, and should be completed for select interfaces by Q1 2025. PI Interface for Emerson DeltaV Batch and PI Interface for Siemens SIMATIC Batch will be the first interfaces to release with this functionality.
      Mar 25, 2024
      We upgraded the EMDVB interface to version 5.1, but unfortunately the features is not available.
      We are forced to use an old version 3.x to collect records where the UNIT is not selected.
    • Tim Proeber
      Mar 5, 2024
      Sometimes a [UNIT] is not selected, and we want to detect this in a Tag Template.
      Dec 27, 2022
      This feature was available in version 3.x of EMDVB (Emerson DeltaV Batch Interface)
      The lack of this capability in version 4.x is a serious backwards compatibility issue.
      We hope a new release will be available in a short time.
      Aug 17, 2022
      The capability to interpret blank fields would be very beneficial. The addition of reading S88 batch levels 1-6 [Level] would also be useful.
