Batch Framework Interfaces - Officially support fanning tag data to a PI Collective
Unlike other PI interfaces, the Batch Framework Interfaces do not use buffering. If the interface loses connection to the PI Data Archive, the interface continues collecting data and stores it in its local cache. The PI Batch Database is primary-only so it did not make sense to fan data to other PI Collective members. However, this is no longer a consideration if Event Frames are being written. There should be an officially tested and supported way to fan tag data to a PI Collective.
    • Admin
      Ellery Murdock
      Jun 6, 2024
      Batch Interfaces support buffering with the latest 5.x releases. Please review your batch interface's release notes for additional information.
    • Alex Santos
      Apr 17, 2024
      This was implemented on versions 5.1.x of all PI Batch Interfaces. More detais in the article How to buffer data from a PI Interface for Batch/MES
    • Marcus Hultgren
      Apr 21, 2023
      The PI EMDVB getting the buffering capacity would be a huge benefit!
    • Kenneth Reiss
      Dec 6, 2022
      This was widely talked about by attendees to AVEVA World 2022. I hope we can see some work on this.
    • Nate Anderson
      Sep 15, 2022
      This is a common request from our customers in chemicals and pharma - adding a second interface to bring in data to the secondary is not at all ideal, and the missing batch tag data on the secondary greatly diminishes the value of a collective.
      Sep 15, 2022
      I have heard a lot of feedback that the power users of our batch data need this to adopt.
    • dbac
      Sep 15, 2022
      This is very much needed by customers that heavily utilize batch data, but are reluctant to adopt this without official support.
    • Mineeshmon Mathew
      Sep 2, 2022
      It would be absolutely helpful to implement this. Great idea and full support!
      Aug 17, 2022
      Writing tag data to secondary PI server via Batch Interface would be very helpful for us too!
      Aug 17, 2022
      We could definitely use this... that way my users won't have to worry about "missing" data when they are looking at the other collective members!!
    • bgoldinger
      Aug 17, 2022
      Makes sense - I had a mfg site decline to implement a collective at first because they might be missing batch data if looking at the secondary server in the collective.
    • Roberto Gubellini
      Aug 17, 2022
      It would be a great improvement for us too.
      Aug 17, 2022
      This would be a huge improvement. We are forced to use Tag Templates with our Werum PAS-X Batch Interface since the Business Integrator does not publish data until the event is closed and our records can remain open for 2+ weeks. We plan on publishing the same static attribute data generated to tags but not supporting buffering (essentially not support a collective) is a huge issue at our site.
      Aug 17, 2022
      This is a no brainer, definitely should be supported.
    • Kai-Uwe.Tappert
      Aug 17, 2022
      Good idea! Please implement this feature.
    • vpolvoreda
      Aug 17, 2022
      It would be a great improvement.
    • TanjaHeite
      Aug 17, 2022
      Great idea. Please implement this.
    • Rebekah_Wilson
      Aug 17, 2022
      I agree that it is necessary to have batch interfaces fan data to a collective. In our use case, we rely on batch data to trigger analytics. Without data going to both collective members, we have no way to ensure our analytics are only connecting to the primary server without subsequently impacting buffering on our analytics outputs. This is really a large oversight with the batch interfaces as OSIsoft continues to grow the analytics capabilities. If batch interfaces do not support buffering, other products need to be able to accommodate this deficiency.
    • Monica Rattaggi GSK
      Aug 17, 2022
      It would be really helpful.
      Aug 17, 2022
      Absolutely on board with this functionality.
