Status Planned
Product PI Interfaces
Categories Batch Interfaces
Created by Bethany Jewett
Created on Mar 21, 2024
PI EMDVB Interface should not use the STARTUP.dat to determine recovery start time when configured in Failover and running in RealTime mode.
Currently when the PI Interface for Emerson DeltaV Batch (EMDVB) is configured for failover and running in RealTime mode, the interface will use a recovery start time (RST) based on the last time the interface was active.
This results in the interface performing history recovery for an excessive time interval in the scenario where one of the failover instances is idle for a long period of time and then becomes active because of a failover.
Instead, the interface should look at the failover tag to determine when either interface instance was last active and adjust the RST accordingly.
  • Admin
    Ellery Murdock
    Oct 8, 2024
    This is planned for a Jan 2025 release. As this fix is in the batch framework, all batch interfaces released after Jan 2025 will natively include this enhancement.
    As suggested, the secondary interface will use the failover tag to determine the history recovery timeline.
  • jeff_denz
    Oct 2, 2024
    While I think this is obvious based on the explanation already given, an example of how this is problematic is during monthly patching. If the goal is to be as seamless as possible during patching activities, we do not wish to attempt recovery of 1 month worth of batch data during every patch. This can take hours in our case. Because of this, we have had to set the backup services to manual, only to be used in extreme circumstances. Therefore, the redundancy is nearly useless to us until this issue resolved. Please give serious consideration to updating this behavior.
    Hours vs seconds of recovery time during failovers is the difference.
