Product PI Integrators
Created on Aug 16, 2022
Provide support for automatic updates for PI data in Event Views
There are automatic updates for PI data in Asset Views and Streaming Views, but not currently in Event Views which is what's used for Event Frames. This is important for propagating changes in EFs Use case example: GADS classification. Data comes in and EFs are created. The integrator picks this up and sends the info along. Some time later (maybe a few days / maybe month end) data comes in re-classifying / updating the original data (ex. GADS code or attributes). In order to accommodate this manual intervention using the "Update Data" button is required.
  • Nuno Carvalho
    Nov 5, 2026
    We are using PI Integrator for Business Analytics 2020 R2 SP1. An Event View named IMBS_Eventos is configured to publish to Microsoft SQL Server every hour.
    The scheduled publications run successfully and write rows to the SQL table. However, when an Event Frame that has already been published is subsequently modified in PI AF, those changes are not reflected in SQL during subsequent scheduled runs.
    For example, users may correct the cause, classification or comments of a stoppage after it has ended and been published. These corrections normally occur within seven days of the event ending.
    If we manually select “Update Data” and reprocess the relevant time range, the changes are correctly reflected in the SQL table. Also if we refresh "Update Data" with a frequency of 1 min for a short period also the SQL is not updated.
    The attached logs show successful hourly publications and a subsequent manual backfill. No errors are reported in those executions.
