Status Completed
Product PI Integrators
Created on Aug 16, 2022
Preserve view model when PI AF Server is changed
As a PII4BA user I need to create same views pointing to different PI AF Servers, when I change the AF Server, the view model is lost. It should check if templates and attributes exists on this AF Server, and if it is consistent, preserve the view model.
    Aug 16, 2022
    This capability is available through the Import/Export feature under Administration > Views. You can export the view and import it and change the AF server/database during the import stage and UI. This capability has been released since PI Integrator for Business Analytics 2018.
    Reply
    Aug 16, 2022
    As an Integrator user with multiple AF servers and databases organizing my data, I would like the ability to use a shape from a view pointed towards AF Server 1 to populate a new view for assets on AF Server 2 that match the shape. Currently, when I try the "Use a shape from a different view" option in the Integrator Designer, the asset shape clears as soon as I select a different server.
