Status Completed
Product PI Integrators
Created on Aug 16, 2022
Add support for Kerberized Hadoop
We would like to use the Integrator to publish to a  Kerberized Hadoop cluster (Hadoop that uses Kerberos tickets). Currently this is not supported by the Integrator (Enhancement 148795.), and if you try to set up a Hadoop target that is a Kerberized Hadoop cluster, you will see the error: "HadoopHDFSWriter::GetHomeDirectoryAsync: Request failed. Authentication required Result: ...401 Authentication required..." Current workaround: publish to a SQL Server target instead and then use a Hadoop tool such as Sqoop to bulk copy data from the SQL Server to Hadoop.
    Aug 16, 2022
    This request has been addressed and completed in the 2018 release. See release notes for additional details.
    Aug 16, 2022
    This feature will be included in the release after PI Integrator for Business Analytics 2016 R2 SP1 which is currently scheduled for Q1/2018.
    Aug 16, 2022
    We will be adding support for Kerberized Hadoop via Knox Gateway.
    Aug 16, 2022
    Adding the request to support standard kerberos support for the Cloudera hadoop package. For Cloudera, Knox is not supported.
    Aug 16, 2022
    In the 2018 release, we will add HttpFS support to the Hadoop writer, which can be configured for Kerberos security in Cloudera Hadoop.
    Aug 16, 2022
