Always produce output table on publication: if there is no data to export when an asset view is published, produce an empty output table
I build asset views on a schedule with interpolated time points based on a PI Point. I also set these up before any data is added to the PI Point so on first publication there is no data to export. Currently the PI Integrator for Business Analytics does not produce an output table if there is no data to export so any downstream SQL queries will fail since the table does not exist. If the output table was always created on publication, and an empty table was created when there is no data to export, this problem would be fixed. Also in the past due to other technical issues some asset views I created did not publish, without warning. If in the absence of data an empty table was created on first publication it would provide feedback that the publication was successful.
    Aug 16, 2022
    Thank you for sharing your feedback on the PI Integrator for BA. After reviewing this idea, we have decided to decline it, as our current engineering efforts are focused on cementing product stability and reliability, and we don't expect that we'll be able to prioritize this idea in a reasonable time period. As far as downstream applications, ideally these can be configured to more gracefully handle situations where a table is not created. Regarding instances where a view did not publish without warning, we recognize this can be a pain point, and are evaluating approaches that may better serve that need.
