Bypass Certificate Prechecks for PI Integrator Upgrade
Similar to PI Web API certificate feedback recently implemented in PI Vision 2020. If PI Integrator is currently using a 3rd party certificate and is upgraded- have installer bypass certificate prechecks and continue to use the same certificate with the upgrade. Some customers have restrictions on the servers where we need to install the SSL certificates, that make it impossible to verify the validity (e.g. no access to revocation servers). The certificate is accepted by clients as those have different authorisations. I would like to optionally bypass the certificate checks in the PI Integrator installer to allow using the same previous certificates that cannot be validated. This will save a lot of time to bypass the utility and manually remove and bind a certificate.
