Support ArcGIS Print widget
Example customer use case: In order for the HSE team to drive continuous improvement, it is desired to integrate real time data and GIS maps, and be able to export findings in a certain area of the map into a pdf format (using the Print Widget) which can then be saved for future use and also shared among the team. When turning on only static layers (layers that are not published by Integrator), the printing works fine, but having a static pdf is not of much use to the HSE team and they need to see the layers on the map. When (time-enabled) layers published by Integrator are also included for printing, the printing fails.
    We have decided to decline this item for now, as we are focused on high priority work in other areas of the PI System. However, ensuring our users can leverage their operational data across a variety of tools and platforms is a challenging, but vital aspect of making sure your data is valuable and accessible, and your feedback is instrumental in helping us understand how to shape these efforts. Thank you for sharing!
