Allow Oracle schema to be configurable
As a PI Integrator user, I would like to be able to specify a schema for my Oracle publish target so that the Integrator only uses the schema that my Database Administrator specifies for me. Currently it is not possible to specify a schema for the Integrator to use, so it will use the Oracle logon's schema by default.
      Reply
      Aug 16, 2022
      Note: A logon trigger may be a viable workaround for this issue as in the following Stack Overflow post: https://stackoverflow.com/questions/283589/oracle-setting-per-user-default-scheme-not-altering-a-session. Please consult your Oracle administrator if you are considering this option.
