Allow Modification on PI Integrator published view
Often, once a view is published, we would like to add a tag to it. Unfortunately, for this we need to copy the view and it'll create a copy of the target, forcing us to backfill again all the view. We would like this to change. Knowing that other companies would like to keep published view locked, this is our proposal: - when a copy of the view is made, on the publish panel, you can select a target and also choose to create a new table or select an existing table. -> This will allow us to publish to the same table as before and allow other client to keep their published view locked. To be developed: - A mechanism to check that each table is alimented by only one view. - When you select a table target, a mapping must be done to keep the track between the previous view and the new one. (tag add / deletion)
