Created on Aug 16, 2022
Including the name of the report parameter used in the print-out PDF's file name
It would be much easier to browse the output print-out PDF files from the RTreports generator if the file's name includes the report paramater under which the report was generated. At the time being, the report only includes a unique GUID for each different parameter which wouldn't be helpful if multiple print-outs are generated respectively for different report parameters. One example: Let's say there are X amount of elements in an AF tree derived from the same AF Template and we want to generate printed reports for every single element. We would want to realize this with only one report template, because all elements are technically identical. Thereafter, when we generate the reports, we will find X amount of reports in the same folder. These would have almost identical names with only the unique GUID differentiating them from each other. We would then have to search manually for the report of interest which would be very time-consuming if the X amount is significant.
