Categories Ad Hoc Analysis
Trend Digital States and Enumeration Sets
Trend Digital States - Currently on a Trend Graph that is trending digital state tags, viewing the Y Axis, you can only see the bottom value and the top value within a given timerange, whereas any state that is in between this range is not represented on the Y Axis, unless you change the timerange, or hover over the in between state to see the value. Please add all Digital States in there proper location on the Y Axis. While trending AF attributes that are linked to an enumeration set, and all the attributes share the same enumeration set, then in case the user selects the option “single scale” he/she would expect to be able to see the string value (Name) on the vertical axis instead of the integer (Value).
  • Pete Long
    Jan 11, 2023
    I would understand that it's impossible for different digital states and to make that somehow work would be an enhancement request. When all tags share the same state set, not being able to combine them into a single scale (when they display so nicely in multiple scales) sounds more like a bug to be fixed than an enhancement request, at least in my high maintenance opinion.
    Particularly when opening an event frame from a notification link, it can be confusing for users to see no historical trend for a digital state the same way it works for any numerical values. Currently it just shows a blank box where the trend show be. We have a high volume of tags with more than just 2 states so being able to see the timeline how it got to a certain state would be useful information.
  • cristina.bottani
    While trending AF attributes that are linked to an enum.set, and all the attributes share the same enum.set, then in case the user selects the option "single scale" he/she would expect to be able to see the string value (Name) on the vertical axis instead of the integer (Value).
