Status Completed
Categories Administration
Remove requirement for SQL setting 'disallow results from triggers' to be set to 0
When 'disallow results from triggers option' SQL feature is enabled and set to 1 on the SQL serverwhere the PI Vision database is hosted, PI Vision displays cannot be saved resulting in error: "A trigger returned a resultset and the server option 'disallow results from triggers' is true" Existing versions of PI Vision do not support this feature to be enabled and must be set to 0 for a proper functioning of PI Vision saving displays capabilities. However, this SQL feature is reportedly recommend to be set to 1 by Microsoft and it is mandatory for some customers to have it this way on their SQL server environment (https://docs.microsoft.com/en-us/sql/database-engine/configure-windows/disallow-results-from-triggers-server-configuration-option?view=sql-server-ver15). To support this, we would like to allow PI Vision to save displays when this SQL feature is set to 1.
    PI Vision 2021 removed the reliance on results from SQL triggers.
