Status Completed
Categories Symbols
Created on Aug 18, 2022
TABLE: Allow Asset Comparison table to be transposed
In the paper industry, there are fewer assets at a site, but those assets tend to have many attributes (e.g., there may only be 3 paper machines, but each has 100 attributes of interest). It would be helpful if the Asset Comparison table in PI Vision could be transposed so that asset names were Column headings and attribute names were rows. For example, instead  of a table with 5 rows and 100 columns (that can't be seen all at once on one display page), it would be better to have four columns of assets names with 100 rows of values, where the attribute name was the first cell in each row. Such as Paper Machine 1....PM2....PM3 Model #    123                        456      789
    Dec 15, 2025
    This item has been completed as part of the AVEVA PI Vision 2025 release. Watch an overview of the new features here.
    For additional information on AVEVA PI Vision 2025, please see the release notes here.
  • jerome.boudon
    May 26, 2025
    Same in Hydro Power Generation, a turbine may have hundreds of parameters
    It is easier with a mouse to scroll down than to scroll left/right
  • Laurie Dieffenbach
    Feb 20, 2025
    Administrator asks:
    1. What specific problem are you trying to solve with this enhancement?
      1. Attribute tables that are too wide to meaningfully display on a screen are easier to view and analyze when they are long instead.
    2. How would you like this feature to work?
      1. How about a toggle to pivot the table?
    3. Who will benefit the most from this enhancement?
      1. Anyone who needs to compare assets with lots of attributes. Probably more engineers than operators.
    Aug 18, 2022
    I'm in the transmission and distribution industry and have the same issue. The number of circuit breakers associated with another element are few but the circuit breaker attributes are many. It would be really good to have the elements as the columns and the attributes as rows. Also the attribute names tend to be longer than the element names so having them as rows would better for this reason also.
  • Brent Bregenzer
    Aug 18, 2022
    I have talked to users from two different customers who have requested this functionality for the exact same reason: many more attributes per asset than assets in the table. Edit: customers are in Chemicals and O&G Downstream.
  • rfesler
    Aug 18, 2022
    I've come across a few cases in the oil & gas industry that this feature would also be helpful for.
    Aug 18, 2022
    Need this, The comparison table is stupid wide because of the lenght of the attribute names.
    Aug 18, 2022
    Current table looks like this: Asset | Attribute 1 Name | Attribute 2 Name | Attribute 3 Name | Attribute 4 Name | Attribute 5 Name Asset 1 | Attribute 1 Value | Attribute 2 Value | Attribute 3 Value | Attribute 4 Value | Attribute 5 Value Asset 2 | Attribute 1 Value | Attribute 2 Value | Attribute 3 Value | Attribute 4 Value | Attribute 5 Value Asset 3 | Attribute 1 Value | Attribute 2 Value | Attribute 3 Value | Attribute 4 Value | Attribute 5 Value Want to be able to change table in case there are lots of Attributes needed in 1 table. The table gets very wide. Sometimes there are lots more Attributes than Assets that is why it makes sense to be able to transpose the table. Column 1 is either the Asset (as it is now) or the Attribute (future feature) Attribute | Asset 1 | Asset 2 | Asset 3 Attribute 1 Name | Asset 1, Attribute 1 Value | Asset 2, Attribute 1 Value | Asset 3, Attribute 1 Value Attribute 2 Name | Asset 1, Attribute 2 Value | Asset 2, Attribute 2 Value | Asset 3, Attribute 2 Value Attribute 3 Name | Asset 1, Attribute 3 Value | Asset 2, Attribute 3 Value | Asset 3, Attribute 3 Value Attribute 4 Name | Asset 1, Attribute 4 Value | Asset 2, Attribute 4 Value | Asset 3, Attribute 4 Value Attribute 5 Name | Asset 1, Attribute 5 Value | Asset 2, Attribute 5 Value | Asset 3, Attribute 5 Value
    Aug 18, 2022
    Need this, as well
  • maumuniz
    Aug 18, 2022
    Would be great to have this for application in our Power Plants. Many attributes to few assets make for way too wide tables.
  • tdeibe01
    Aug 18, 2022
    Exactly the same comment as maumuniz. We have fewer assets with many attributes so this table would be more useful if it could be transpose.d
