Categories Search
Add some options to the "Edit Search Criteria" in PI Vision
Add some options to the "Edit Search Criteria" in PI Vision: The first option would be in the asset type filed. When searching according to the value of asset attributes, the customer would like to be able to specify the realtion between the selected conditions (OR / AND). Secondly, rather than searching by attribute values (which could be not accessible to certain users), the customer suggest also adding the attribute category. So, you can search for assets according to the attribute categories.
  • DeboraG
    In the TABLE, Search criteria, Asset Type, Asset Attribute, I'd like to be able to add more than one attribute with an OR condition because in this version when a add two attributes the condition works like an AND. My case is, there are 5 differents assets with 132 attributes each one, so I'd like to retrieve in the table only the attributes greather than zero but when I add more than one attribute the filter doesn't return the values that I need. In the case number 00945572 you have more details. Regards!
