3D navigable and filtrable plot (XYZ)
Similarly to the XY plot, a XYZ 3D plot would be useful to inspect the trend of 3 variables in a 3D space and visually deduce correlations. Example could be the Environment Temperature, the Gas Valve Opening, and the Produced Power of a gas turbine. This graph should also be filtrable (e.g. I only want to see this data when the machine is operating under maximum power conditions).
    Aug 18, 2022
      Reply
      Aug 18, 2022
      Daniele, Or as noted elsewhere on other XY plot suggestions, ( e.g. such as “Adding / Configuring the Marker Size/Format in XY Plot”) add the option for a fourth variable in terms of bubble colour, a fifth variable in terms of bubble size, and a sixth variable, Transparency, (Usually time, with current time being 100% opaque, and setting a historical time for 100% transparency). In the gas turbine case, Power vs Temperature might be the X, Y, but Temperature Z, fuel consumption bubble colour, vibration, bubble size, and transparency set to show the last 14 days of operation from the current time, irrespective of the sample range selected. Many other processes lend themselves to the same approach, with a different set of variables. For a good 3D example that could be used as a basis, (Especially if Amchart and Highchart integration was a standard option) see https://www.highcharts.com/demo/3d-scatter-draggable/dark-unica .
    • AlejandroGL
      Reply
      Aug 18, 2022
      The ability to filter would be very helpful, it is a basic for analysis.
