Categories AF Integration
Created by Willy Seah Wei Liat
Support of more than 1 reason code
As a user, I would like to enter more than 1 reason code per event frame. For example, a downtime event frame is created for the whole production line, and I would like to have a reason code for the cause and the other for the equipment. Currently, AF only supports 1 reason trait attribute per event frame. This also allows PI Vision to enter 1 reason per event frame.
      Reply
      totally agree here.  we need to be very flexible here because many events are caused by a combination of triggers.
      Reply
      We need at least two reason codes for proper downtime tracking and pareto analysis. The comments box is useful for additional explanation but the reason codes must be selected from individual lists to ensure they are consistent for analysis.
    • ehoffman
      Reply
      Multiple reason codes would really help us add additional context to our event frames. Our goal is to tie equipment ids to our event frames to help with failure reporting while still having the failure reason code data. Can this item be reopened and considered?
      Reply
      Also want to to comment that this is absolutely necessary. We need the capability of multiple reason codes so that the downtime events can be efficiently and accurately coded by the operator. I can give them 10,000 choices in a single reason code, or 100 in code 1 and 100 in code 2. Which one do you think they are more likely to get right?
    • J.M. Rodríguez
      Reply
      This is absolutely necessary. I find a lot of cases where it is necessary to classify, as it has been said, in case of a downtime, at least the equipment which caused it and the concrete reason. This split is needed for later analyses. It is not enaugh with having a codes tree. I think that this enhancement should be considered.
