101 VOTE
Status Completed
Created by Dan Coursolle
Event Comparison Display: Allow scale configuration
There is no ability to configure the Y-axis scales on the event comparison displays (database, autorange, custom). If there is an outlier value it can make the chart too compressed to see useful data.
    PI Vision 2021 introduces new capabilities that allow users to configure the value scale on trends within their Event Comparison displays. See an overview of new PI Vision 2021 capabilities on our YouTube learning channel: https://youtu.be/LomuqXKEH7w For additional information on PI Vision 2021, please see the release announcement here: https://customers.osisoft.com/s/knowledgearticle?knowledgeArticleUrl=000037703
    • sjohnson
      Reply
      even trends need to have same configuration options as "regular" trends -- configure x and y axis, change colors, double-click to fill screen, zoom.
      Reply
      Much needed... please!
      Reply
      This is important. A bearing temperature that is only moving 1 degF can look as bad as one that is causing you the problem. Form the SME's viewpojnt, doing root cause analysis from Event Frames is severely limited by the "Multi Scale" approach.
      Reply
      Currently we don't have the functionality to switch from Multi-scales to Single-scale when viewing Event Frames in PI Coresight. It would be useful for comparison between multiple attributes in the Event Frame window. The ability to switch scales between database and autorange would also be valuable.
      Reply
      Any idea if this is in the plans for upcoming PI updates? Having the ability to make trend adjustments in the event frame viewer would be awesome.
    • Dave Greene
      Reply
      Please ensure the control of the Xaxis includes relative to starttime or endtime like PI Batch would do. Starttime-20m, Starttime+1h to look at details of the startup or conditions just prior to the start of the event. Same as this request - https://feedback.osisoft.com/forums/320517-pi-vision/suggestions/19456825-event-comparison-display-add-trend-configuration
      Reply
      Similar to PI Batch and TrendMiiner - being able to analysis start times to compare details as to other start times. trendMiner does this very well. Lets get PI Vision back on top!
    • +1
