Display propagation between environments in regards to hyperlinks
We create PI Vision Displays in a Test environment, before Migrating them to Production. The Main display has many Hyperlinks to other Displays (and those Displays have Hyperlinks back to Main). When we propagate Displays from Test to Prod, all the links are broken and we spend quite a bit of time updating all of them. Is there a way to have the Hyperlink to another Display in the environment be independent of the Display number in the environment? Or is there a way to manually set Display's number? Related to that, is there a way to propagate a new version of an existing Display from Test to Prod without generating a new Display number for the Display in Prod?
    • Yuliia Pylypenko
      Reply
      Feb 14, 2023
      We have the same problem with broken hyperlinks during copying displays from Test to Prod environment with help of PI Vision 2021 Display Utility. If we need update only some of existing displays, the hyperlinks are broken after copying. Could you improve a mechanism of updating existing displays such way that hyperlinks with ids of Test environment are changed with ids of Prod environment and will be correct after copying?
