371 VOTE
Status Completed
Categories Symbols
Created on Aug 18, 2022
PI Vision tooltip configuration
The user would like to have control over the tooltip configuration of the PI Vision symbol. For instance, he would like to show the tag of a PI Point data reference when hovering over a single value from an attribute.
    Dec 15, 2025
    This item has been completed as part of the AVEVA PI Vision 2025 release. Watch an overview of the new features here.
    For additional information on AVEVA PI Vision 2025, please see the release notes here.
  • Mike DiMascio
    Jun 26, 2025
    When hovering the mouse pointer over any object (value, symbol, text), the tooltip can be user customized with whatever information the user chooses including simple text. Value: get additional explanation of the value, how its derived, how it can be used. This is a common feature on all good visualization displays in other platforms and user interfaces.
  • Max Chung
    May 30, 2025
    It would be extremely helpful to have a robust clipboard feature that allows users to quickly copy tag names from the tooltip. This would eliminate the need to memorize tags when creating Excel reports or other documentation—especially in cases where the actual tag name is required for regulatory compliance. While the Asset Framework (AF) is useful, the alias often can't be used in official reports, as some regulatory tag names have remained unchanged for decades.
    My users expect modern websites to support intuitive copy-paste functionality, allowing them to easily reuse content in their own workflows.
  • asanzacedo
    Apr 22, 2025
    This was a really good feature in ProcessBook
    It was very helpful to see the instrumenttag the tag is pointing to, or any other attribute that may be relevant at the time
    Also adding attributes on the search panel in ProcessBook was very helpful to check atrributes for multiple tags at the same time
    I would be really good to add these features in PI Vision
    Regards
  • EmmaLM
    Mar 11, 2025
      1. To be able to provide users with extra information, be that additional data or a free text message.
      2. To reduce troubleshooting time for admins, by being able to quickly locate information.
      1. Content:
        1. ability to use all of the possible substitution parameters, and attributes associated with a value whether it be a PI tag or an AF attribute; and
        2. be able to use free text; and
        3. be able to include symbols or select a style for the tool tip bubble - for example types of: Info, Warning, Data-source, Operator Action; as this would assist with the ease of interpretation for the users.
      2. Configurability:
        1. ability to include the substitution parameters in any order that the creator desired; and
        2. the ability to set some defaults would be time saving and provide the opportunity for consistency; and
        3. some permissions controls on this might be useful or we could get some very interesting tooltips! Perhaps free text or certain types of tooltip (e.g. Warnings, Operator Actions) would require admin permissions - otherwise there is the potential for it get very visually-noisy for users
    1. Ideally it will be equally beneficial to PI Vision Users and Admins: users will benefit from the additional information/direction; and admins can save time on troubleshooting/explaining.
  • esb_support
    Mar 7, 2025
    We would like a configurable tooltip, at a minimum users need to see the min, max and average values of a pi point on hover, but being able to configure what data is shown per display would be preferable. We would also like to be able to alter the text formatting of the tooltip, increasing the text size as many Displays we use are in communal areas for monitoring and may be at some distance from the user.
  • Sam.P
    Feb 24, 2025
    1. To stop users spending unnecessary time creating multiple displays where one switchable AF based display would suffice. At the moment we cannot convince users to use an AF database because they have no visibility of the underlying tag unless they have PI System Explorer.
    2. In the configuration of a trend/value etc, you should be able select what parameters are shown within a tooltip.
    3. Users will benefit from being able to make use of asset switchable displays and admins will benefit from a reduction in questioning about what tag is used in an attribute.
  • rphilp1
    Feb 21, 2025
    I have a number of use cases for tooltips
    • Providing visibility to additional info on a visual component linked to a pi tag or attribute, as has been previously discussed
    • Providing additional context or explanation for a display or display component. This might provide an explanation of what the display or component means, or suggestions on how to interpret a display
    • Providing a place to temporarily display additional attributes. Often a display is crowded, and data of secondary importance might not fit easily. A pop up panel could provide a place for a peek into additional data via attributes or pi tags.
  • Rick Smith Jr
    Feb 20, 2025
    I agree with the comments below regarding showing the PI tag, but do not just assume it is a PI tag. We also have cases where we use formulas to synthesize a value instead of writing analytics to output to a PI tag. The tool tip should have the option to display the data reference and settings field...
    The first thing I wrote in the 1980s (in Fortran) was an enhancement to our home-grown process visualization tool. We could not hover to get a tool tip, but clicking on a button replaced the values displayed with the data source (tag or formula) at the location on the display. This saved hundreds of hours of troubleshooting every year between end users and the developments.... I would have the same expectation in this case as well.
  • MattBa
    May 3, 2024
    It is very interesting to me that folks cannot see a PI tag name when looking at an AF object. I'm very surprised. We had to purchase additional PI Vision tools to make Vision usable. We used a company called Software Athlete. It is very inexpensive and the offer support for tooltips and showing PI tag names.
  • PetraR
    Jul 24, 2023
    The 2 main reason why this tooltip configuration is needed
    • Ease of use for our customers
    • Timereduction during troubleshooting
    Already 288 votes are on this topic so this means that it's beneficial for a lot of customers!
    More details:
    To be able to check the correct tag configuration in AF for end users it would be a good improvement to be able to see the pi tagname in the tooltip of an AF PItag attribute.
    Because the end user currently does not see the AF configuration of the pi point in pivision, they have to contact backend engineers to get the used tag configuration, which they need to check if the correct tag is used in the pivision screens.
    This creates unnecessary delays in updates and corrections of displays and assets and offcourse extra request to the backend engineer.
  • Kaity Hillgartner
    Jun 8, 2023
    I'd like to use tooltips to provide information about the tagname of a PI Point present behind the AF attribute
  • Maninder Singh
    Mar 30, 2023
    Having the tag name avaliable would allow me to look at the P&ID and DCS for the affected system and act on off aim conditions faster.
  • Brian Mayfield
    Mar 17, 2023
    In addition to Abigail's comments, the tool tip is essential for efficiency in troubleshooting. E.g. An operator reports that certain values are not updating on a dashboard. These issues are reported to tech support. The first question is always "What is the tag name or tag names that aren't updating?" IP21 has the feature on their portal displays that when you hover over an indicator by default the tool tip indicates the specific tag number. The tool tip can be overwritten, but this is the default setting. The lack of this feature is the #1 complaint of new OSI PI Dashboard users at our site.
  • Abigail Hall
    Mar 17, 2023
    The ability to customize the tooltip (i.e. to show the instrumenttag field) or similar, would be a significant improvement in our ability to integrate the use of Pi vision with other systems (maintenance databases, P&IDs, DCS, etc.) that continue to use instrument tag names.
    Feb 10, 2023
    Tooltip Statistics was one of my most-used features in Pi ProcessBook. I find it very difficult to use Pi Vision without the option to display additional information about a tag by hovering over it, in particular the name/description which saves a lot of time when unfamiliar with a display.
  • Lucas José Calderón Ponce
    Dec 16, 2022
    In my experience, it is something that has been requested several times. I believe this should be something easy to implement and very useful.
    My suggestion, Instead of involving the tag name or tag descriptor from the DA to an Attribute in AF, an easier way to implement it would be to add to the current visibility label options the AttributeConfigString (only for Attributes which have a PI Point as data reference), simultaneously being able to combine it with the Element Name,Attribute Name or the Attribute description.
  • Ravneet Randhawa
    Oct 24, 2022
    please add this feature. a lot of users want to know the average value of the tag at a glance which is how they used to do it in processbook
  • LGaudreault
    Oct 18, 2022
    I would like to have a tooltip on header of column in a event table, to show the complete name of the attribute of the column.
    Aug 18, 2022
    For pharma , we need to qualify every components. Of course AF , is part of OSIsoft software. Some customers asked us to confirm the tag name associated with attribute when they use PI Vision through AF structure.In this way , management can use AF structure only, and instrumentation people in dragging over the AF attribute the can see the tag name ( useful for them for troubleshooting ) . The best will be to have AF attribute description follow by | and tag name
    Aug 18, 2022
    I'd like to use tooltips to provide information about warnings on the screen. For example, the status of a machine reliability indicator is currently red. I'd like to have tooltips to guide the operator on what are the possible causes and common actions needed to revert that scenario.
  • Load older comments
  • +271
