Status Completed
Using ONE display to link to multiple related assets
This took me a long time to figure out, but you can already do this, just not easily Say you make a display for Engine 01 and it shows RPM HP and Fuel. You can then take the link and modify it so when you get an alarm for Engine 09 you can use the same display but send an email with a URL that will show engine 09 data. There has to be a way we can simplify this. IE: https://X.com:/Coresight/#/Displays/655/Main-Unit-Diagnostic https://X.com:/Coresight/#/Displays/655/Main-Unit-Diagnostic?Asset=\\SERVER\AF NAME\FOLDER\Main Unit 09
    The asset parameter can be used to change the AF context of a display, or an alternative is to use the asset list. By default the asset list shows elements based on the same template as other assets on the display, and starting in PI Vision 2017 R2 you can configure search criteria to control which elements appear in the asset list.
