PI Manual Logger’s Conditional Manual Data Entry feature should allow conditions based on tags that are not part of the tour
Tags within the tour may require data entry based on the value of status tags for which data is never entered manually. Use Case: Say there is an asset called Pump1 that has many related tags (e.g. Pump1.FlowRate, Pump1.Pressue, Pump1.PowerConsumption, etc.) which are members of a tag group within a PIML tour. If the pump also has an associated digital tag called Pump1.Running that can be either TRUE or FALSE, it would only make sense to enter data for that tag group if the value of Pump1.Running is TRUE. Otherwise, the tag group should be skipped. In this case, you would never want to manually enter data for Pump1.Running (that should come from the instrument monitoring the pump), but you need to know its value during the tour.
    Thank you very much for sharing your feedback. After evaluating it further, we have decided to decline this item, due to other high priority engineering needs across the PI System. Thank you for your feedback, and know that we are listening and reviewing every item that gets submitted!
    Here is a configuration you can use to hide the conditional tag. In this case, it's BA:ACTIVE.1 The CMDE: if(LastArchiveValue("BA:ACTIVE.1")==DigCode("Inactive","BA:ACTIVE.1"),CollectNow(),Skip())   To hide BA:ACTIVE.1: if(IsUnknown(CurrentValue("BA:ACTIVE.1")),Skip(),Skip())
