Categories Manual Data Entry
Created on Aug 21, 2022
Notification/Event Acknowledgement: Support 21 CFR Part 11 Electronic Signatures
Include functionality to support the pharmaceutical industry electronic record and electronic signature requirements (21 CFR Part 11) when acknowledging an event or notification, when setting a reason code, and when commenting. This would require the forcing of the Username / Password of the user and potentially some text describing the meaning of the signature.
    Aug 21, 2022
      Reply
      Aug 21, 2022
      We are being forced to look at other software options to gain this ability.
    • FranzK
      Reply
      Aug 21, 2022
      that would be great. for processbook we had to program an own plug in. hope in coresight this comes out of the box.
    • FranzK
      Reply
      Aug 21, 2022
      There is also a need to comment on PI Tag values with electronic signature!!!
      Reply
      Aug 21, 2022
      I would like to add a recent feature to this list - Reason Codes should also retain some type of history - currently there seems to be no evidence of who saved the last reason code entry nor what previous values may have been
      Reply
      Aug 21, 2022
      Include functionality to support the pharmaceutical industry electronic record and electronic signature requirements (21 CFR Part 11) when manually entering a comment on an event (event frame). This would require the forcing of the Username / Password of the user and potentially some text describing the meaning of the signature.
    • FranzK
      Reply
      Aug 21, 2022
      regarding this it should also be possible to configure if a Comment/Reason code is required before Acknowledging an Event - as this might also impact other applications, a solution might be implemented on AF/EF level.
    • FranzK
      Reply
      Aug 21, 2022
      added link to PI AF/EF category https://feedback.osisoft.com/forums/555148-pi-server/suggestions/36079924-acknowledge-of-event-frames-requires-reason-code
