Created by Luis Camacho Forero
Created on Nov 28, 2022
Change the tooltip behavior for asset-based calculation to differentiate from AF Attribute paths
Currently, when hovering over a symbol that displays a PI Vision asset-based calculation, the tooltip that represents the calculation "path" has the same nomenclature/format as an AF attribute. In this case, the format is <Path to AF Element where the input attribute is located>|Asset-BasedCalculationName.Column, which can be confusing since the end result is the same as having an AF attribute on the <AF Element where input attributes are located> with name Asset-BasedCalculationName.Column. Thefore, it would be very helpful to change the behavior to differentiate between the two and prevent any ambiguity.
