Status Completed
Categories Symbols
Created by Jason Gogal
Created on Aug 18, 2022
Asset Comparison Table: Label options for attribute columns
The asset comparison table should allow control of what is shown as the column name. It would be helpful to be able to add custom friendly names to columns in asset comparison tables, or to use attribute description.
    Dec 15, 2025
    This item has been completed as part of the AVEVA PI Vision 2025 release. Watch an overview of the new features here.
    For additional information on AVEVA PI Vision 2025, please see the release notes here.
  • David Lopert
    Feb 7, 2025
    * Ability to sort by any column and not just Asset.
    * Export table as csv/xslx
    * Option for AND/OR
    Aug 18, 2022
    Asset Comparison table, Ability to change column names would be usefull
    Aug 18, 2022
    Being able to use an attribute's description as the column header would be good.
    Aug 18, 2022
    The asset comparison table is very limited in customization. Currently there is no way to modify the column name, header height, text font, etc.
  • Rory_EPE
    Aug 18, 2022
    It's difficult to use asset comparison tables with long attribute names (especially when using child attributes)
  • zwhite
    Aug 18, 2022
    There is a work around to this, that can be annoying / cumbersome. However here it goes. Requirements: PI Vision 2021 This will require a calculation, name the calculaiton the new column name you want. In the asset field drop in the relevent asset. the calculation for me is as follows > if BadVal('asset attribute') then "No Data" // you can leave this out if you don't mind displaying bad status to user > else 'asset attribute' Add this calculation to the comparison table and voila. This a bit janky but is a work around in the mean time.
