Configure TAGs at the same scale group. Allow more than one trend scale with automatic range.
This idea avoid selecting manually each minimum and maximum scale ranges for each one of the TAGs inserted at the trend. Getting faster trend set up, and better templates.
At Microsoft excel is possible to set two scale ranges with automatic scales. And multiple variables. As an example. A pressure control loop with high low sets. With two control valves position TAGs. So at the first scale tags groups, select Process Variable, Set Point, Set High and Set Low. At the second group, valve position.
