Categories User Experience
Created by Mario Carioni
Created on Nov 14, 2024
Gauge Scale linked to Value Unit of Measure
When we use the Unit of Measure conversion on PI Vision gauges, the scale does not change with the unit.
For example, if our source attribute with Maximum and Minimum limits uses Degrees Fahrenheit, the value of the scale shown in PI Vision will also be Degrees Fahrenheit. However, If we change the UOM to Degrees Celsius or Kelvin the scale will remain in Fahrenheit which will make the gauge basically unusable.
This also happens when converting any other unit for attributes with limits set. It would be ideal if the UOM conversion would be set to the Scale/limits as well. currently the only workaround is to update the default UOM from AF (which some end users might not have access to) or set custom limits on the scale which is more laborious.
*Note* It appears the multi state function works correctly, when we set limits and we change the UOM the multistate panel shows the correct UOM. But the scale still shows the old incorrect UOM values.
  • Alistair
    Feb 26, 2026
    For example, in your Visualising PI course, you instruct us to create a radial gauge on tank pressure, which is in kPa and has range limits of 0 to 150. You then have us change the units in PI-Vision to PSI, but the upper limit on the gauge stays at 150 instead of adjusting to what 150kPa would be in PSI (21.76)
