Categories Search
Created by Francis2
Created on Feb 6, 2025
Pop-up or property for graphic from graphic library (use to find or search the symbol)
A graphic in the graphic library has a name and when you hoover over it, it shows. However once dropped on the canvas of PI Vision it does not show that pop-up name. I did create some custom graphic and I believe it is a property in the file when you save it as SVG. My own graphic that I drop up the canvas does show that pop up with name. So the enhancement would be that a graphic dropped on the canvas has: 1: a pop up with the name, so you can search for it (if the library allows you to search...Idea PIVISION-I-1052) or 2: When using the 'Format Graphic' it shows the image folder it is stored in and name as a property, so then you need to find the symbol, you can find the info.
