I've noticed when a PI-Vision trend end time is not the same as the display end time, PI-Vision will request the full history of the trend at each display update. The historian cache ratio is affected as all the old data is repeatedly requested at the display scan rate.
Even trends with static start & end times will cause this behavior. There should be a way to cache that information in the IIS worker process as is done with trends/displays where the end time is the current time.
