Categories User Experience
Created by Navaneethakrishnan
Created on Aug 5, 2025
Tooltip: Show AF Attribute / PI Tag properties in the search pane
Example 1: Once navigated to the AF element, upon hovering its' respective Attribute, tooltip should be able to show that respective Attribute's configuration like data type, data reference, default value, etc. Similar way upon hovering the AF Element, it should show its' respective Template, Description, etc.
Example 2: once we searched the required tag through tag mask, it will list the result of multiple tags matching to the search mask, if we hover a tag, the tooltip should show description, data type, Eng unit, etc.
Also, these tooltips should be customizable to choose what we want on that particular PI Vision instance.
  • Julian Weber
    Aug 21, 2025
    Hey Navaneethakrishnan,
    You could have a look at this custom PI Vision tool that will autoamtically appear on all PI Vision screens on the let tool pane. It allows you to see all PI Point / AF attribute properties very easily.
    Cheers,
    Julian
