Status In development
Categories User Experience
Created by Martin Kocak
Created on Aug 14, 2025
Add units field to PI Calcs
In Advanced Option there is no way to add UOM to the calculation. Even when you have the value in the display. You cannot populate the 'Unites' under the "Format Value" option.
The only way around this is to use Text and add the UOM beside the value. Cone: when the value changes to a greater values and displays more digits then it can get messy.
I have attached a couple examples.
    Sep 17, 2026
    This item is in development for the upcoming PI Vision 2026 release.
  • Dave Greene
    Aug 18, 2025
    Agree, not having the units for calculated values should be fixed. Workarounds to put units in the name or adding text beside the value are weak. The calculation can be added to AF to add units but the whole point of calculations on the display is to make this available to a wider audience.
