122 VOTE
Status Completed
Categories Symbols
Created on Aug 18, 2022
Trend: Support Trace Markers
Support trace markers on a trend like in ProcessBook
    Aug 18, 2022
    In PI Vision 2020, new trend symbol enhancements were introduced including the ability to show data markers of recorded values. For additional information on PI Vision 2020, please see the release announcement here: https://customers.osisoft.com/s/knowledgearticle?knowledgeArticleUrl=000031641
    • ehoffman
      Reply
      Aug 18, 2022
      This would be a nice feature to have and also the ability to hide the line and just show the data points would be very beneficial to us.
      Reply
      Aug 18, 2022
      Include actual data markers (plot each value stored in database) in the trend in PI Coresight(as in PI Processbook) so that we get to know at which point was value stored
    • sjohnson
      Reply
      Aug 18, 2022
      add markers, set trend line to "none". Important for general trends. Critical (for our users) in Event Trends. often, samples aren't taken until several hours into a batch. Trendline always ON makes it "connect-the-dots" from previous batch to first sample in new batch. Makes Event Trends unusable for us.
      Reply
      Aug 18, 2022
      The additional capability to show annotations and data quality information by dynamically changing the trace marker and then displaying the annotation data quality by cursor hover would be helpful
    • ehoffman
      Reply
      Aug 18, 2022
      Will this also be an option on the Event Comparison trends? The ability to show only markers and really any format trend options would be nice to have.
      Reply
      Aug 18, 2022
      It would be also great to avoid connection line between points as further option in 'format trend' to show plotted points. In genereal I think about discrete data values from measurements, etc.
      Reply
      Aug 18, 2022
      Customer wants the option to disable the trace (i.e., connection between points) for specific trends to better represent the data. The data in question is manually entered.
      Reply
      Aug 18, 2022
      Once a trend marker has been set, users should have the ability to change the "start time" for other symbols on the display to match that trend marker's timestamp. Ex. User has set a trend marker at 13:00, and would like an easy method to set all other symbols on the display to show values for that marker's timestamp.
    • Jason Gogal
      Reply
      Aug 18, 2022
      Allow trend traces to appear as scatter instead of line. The normal trend symbol seems to perform far faster than XY plot. However, the trend symbol can only appear as a line and this reduces clarity for some use cases.
    • Jordan_Sellers
      Reply
      Aug 18, 2022
      In response to Ryan McErlean, "We are currently researching this item a..." We've had many requests from users for this feature.  When you have a trend of data from samples that tend to have repetitive values, it's not easy to tell if a sample was forgotten or did not successfully write to PI.  It looks the same from the trend.  This would also help provide intuitive understanding of the frequency of the samples if you're not intimately aware of the sample routine.
    • ehoffman
      Reply
      Aug 18, 2022
      In cases where we do want to use the "show markers" feature we will want to see ALL of the raw data points. This would be helpful for our tags where data is not written as frequent.I think it would be reason able to show ALL markers up to a certain number whatever that may be. I know in Process Book when you have markers enabled it won't necessarily show any of the markers until you zoom in a bit if it's a busy pi tag while the less noisy tags show their respective markers without having to zoom in.
      Reply
      Aug 18, 2022
      We would want ALL raw data points, just like ProcessBook.
    • Matt Voll
      Reply
      Aug 18, 2022
      "Would it be acceptable to show markers for only some of the raw values as long as there are enough to accurately represent the data, ...." Absolutely NOT! This would make 'trace markers' uselss! show all data points. I would expect, like Processbook, that if there were too many data points on the trend to be displayed properly that the markers would essentially turn off and the trace would merely be a line, until such time as the time range was shrunk to a point where ALL data points could be shown.
    • Jordan_Sellers
      Reply
      Aug 18, 2022
      Would be great if we could see every point with the capability to hover the cursor over each of them to see the value and timestamp (or other stats). The scooter bar in Vision is a poor substitute for the capabilities, in this regard, that are available in Processbook.
      Reply
      Aug 18, 2022
      The requirement is for all data points to be shown.
    • jerome.boudon
      Reply
      Aug 18, 2022
      We would need a marker for each value present in the Archive. Ideally, overring a marker could display a tooltip with date, value and questionnable status at least
    • JanWortmann
      Reply
      Aug 18, 2022
      I like the idea of switching to a line when there are too many markers over the trend duration. But when markers are shown no one must be missing. Otherwise this would lead to misinterpretations of the trend.
    • Carlos Garcia
      Reply
      Aug 18, 2022
      When you choose to see the markers that is because you need to see all the information stored in the system: is a graphical manner to see all the records, rather than going through a table. The graphical view of all samples enables to identify gaps, areas with high local variations etc. Based on above when selecting to see markers, all of the data samples represented should have a marker, rather than an arbitrary part of them
      Reply
      Aug 18, 2022
      Is it possible to show only the markers and make the line between them invisible ?
    • Ryan McErlean
      Reply
      Aug 18, 2022
      Yes, turning off the connecting line to only show markers will be possible. This specific request is being tracked in another item that is also in development for the next release: https://feedback.osisoft.com/forums/320517-pi-vision/suggestions/20443432
    • +22
