Categories User Experience
Created by Ee Sheing Lee
Created on Aug 18, 2022
Option to disable PI Vision Mobile Redirection fully (mobile website)
Based on the size of the device or browser window, the user of a smaller device or browser is by default redirected to the PI Vision mobile website. However, we would like PI Vision to have a native function to fully disable this redirection to mobile site instead of using the workaround below To bypass this behavior, we do can add 'redirect=false' to the PI Vision URL. For example: https://webserver/website/#/Displays/DisplayId/DisplayName?redirect=false
  • bjartee
    Feb 2, 2026
    You can test workaround - adding a rule to catch the mobile site in the link and add ?redirect=false to the address. Initial testing seems to be successful. Use the string inside of the single quotes. If you use load balancer the setup will need to be done on all PI Vision servers IIS:
    - URL Rewrite Module needed (v 2.1 from Microsoft - IIS)
    1. Select PI Vision Application
    2. In the Features View, click URL rewrite
    3. Click 'Add rule' > select 'Blank rule' and choose a name for the rule (e.g. Disable Mobile Site)
    4. In Requested URL, select 'Matches the Pattern' and 'Use regular expressions' option. Then enter 'Pattern' = '^m(/.*)?$'.
    5. Keep 'Conditions' blank.
    6. In 'Action' select 'Action Type' = 'Redirect' and 'Redirect URL' = '/PIVision{R:1}?redirect=false'
    7. Uncheck 'Append query string' and select 'Redirect Type' = 'Found (302)'
    Now testing with a screen or emulator that has a lower number of pixels should give access to regular PI Vision. Even if you manually add the /m in the PI Vision link for mobile version it will take you to normal PI Vision.
