Status Completed
Categories User Experience
Created on Aug 18, 2022
Trend: Edit trace name in legend or be able to add a description
Edit the trace name or add a description in the legend of a trend in order to: 1) Make clear the description of the Attribute in the trend 2) Use an abbreviation for the attribute description in the trend legend 3) Use a different language in the legend while respecting the attribute name (for example, an attribute name is written in English in PI System Explorer but we would like to see Italian in the Coresight trend)
    Aug 18, 2022
    In PI Vision 2020, new symbol enhancements were introduced including the ability to add element name, attribute name or description, or custom text as labels for trend, value, vertical gauge, horizontal gauge, and radial gauge symbols. For additional information on PI Vision 2020, please see the release announcement here: https://customers.osisoft.com/s/knowledgearticle?knowledgeArticleUrl=000031641
    Aug 18, 2022
    with pi vision it would be nice to be able to have the option to select the pi tag description to be shown on charts, rather than just the pi tag name. some people follow pi tag naming convention and some dont. being able to select the description would make life much easier to move from process book to pi vision for my group.
    Aug 18, 2022
    It would really help if you were able to change the name of traces in trends. The names on the attached file are both long and not really informative.
    Aug 18, 2022
    be able to change the tag name in the trend view like you can in the value sysmbol
    Aug 18, 2022
    I would like to be able to add a description independent of the descriptor in the database because depending on why you create the trend it may have a deferent meaning. Such as KO drum pressure vs 1st stage suction pressure.
  • alouette_pelr
    Aug 18, 2022
    add the possibility to change trace's name in the trend. Like the value symbol
    Aug 18, 2022
    need to be able to customize the labels of the graph items. Some items have too much information and can be misleading... example: OTHER/MS-2922 SLUDGE TANK LEVEL. We should be able to delete "OTHER"
    Aug 18, 2022
    Hi, being able to set a custom Name would be quite helpful for us. Do you know when a release is planned with that functionality?
  • DannyTaylor
    Aug 18, 2022
    When developing a trend in PI Vision, there aren't any options to provide alternate descriptors for each trace other than the element/attribute for the trace. Can we get an option to update/adjust this descriptor, similar to the "visibility" option currently available when putting a value into PI Vision? This will REALLY help when putting multiple PVs on the one trend :)
