Categories User Experience
Created on Aug 18, 2022
Display property to hide asset/event pane
For smaller screens, the asset/event pane can take up a lot of real estate. The kiosk mode hides the asset/event pane. Unfortunately, it also hides the asset selector drop-down. This improvement would hide the asset/event pane but allow use of the asset selector dropdown. It would be ideal to be able to set a default (display setting) for each display and to have the option of passing a parameter in via URL to override the selected default.
    Aug 18, 2022
    Aug 18, 2022
    Our specific requirement is to be able to hide the asset/event pane by default but still be in standard mode (ie: not kiosk). We would be happy with a system-wide setting for this so that the default is to open all displays with it not expanded (unless it is a 'new' display - creating from scratch). If the user wishes to use the pane, they will click the icon to expand it.
  • John Swartzentruber
    Aug 18, 2022
    The hidesidebar URL parameter should do what you are asking for. Also note that by default the asset/event pane will be closed when opening a PI Vision display. It should only be open by default on Event Comparison displays or when creating a new display.
    Aug 18, 2022
    I would also like to use the asset selector dropdown on mobile devices.
