Created on Aug 18, 2022
Data line graphs points color changes for different value ranges
For graphed data in PI Vision, I would like to be able to use limits on the data (either direct to the point definition or local to the PI Vision page) to either have the data plot line change color on the display as it passes from normal to hi to hi-hi to OOT. (or the background to change so if you cross HI, the background is now yellow at this point moving up). This would be similar to Multi-State options which do not, today, exist for graphs. I use dozens of plots in a column with from 1 to 4+ points per plot but am focused on a graph where I could have 1 primary point that controls the background/line color (or multiple lines changing color would be amazing). This would allow me to more rapidly see lines passing through phases/oscillations that are outside of our desired bands.
  • Nathan Skitt
    Jan 17, 2024
    There is a potential workaround:
    PI Vision Trend Color changes by range.
    KB - 000035673
    https://customers.osisoft.com/s/knowledgearticle?knowledgeArticleUrl=000035673
