Created on Aug 18, 2022
Find and replace/update tag names using PI Vision Display Utility
The PI Vision Display Utility should be able to find and replace PI Points and AF Attributes by name. A situation where this could be necessary is as follows: 1. A PI Vision display was built for using PI Points from a certain data source 2. A new data source, possibly a new instrument, is added to read the same process data. The old data source is taken offline. 3. To keep data separate between different instruments, new PI Points are created for the new data source. New AF Attributes referencing the new PI Points would also be created for similar reasons. Currently to update the PI Vision displays with the new PI Points one has to go through each display and replace all instances of the old point with the new point.
  • asanzacedo
    Jun 26, 2026
    Very useful for changing pi points in bulk on a single PI Vision display
    Aug 18, 2022
    Useful for Displays for Less Knowledgeable Users when changing Data Sources or PI Point Names.
  • Stacy Koos
    Aug 18, 2022
    We need this implemented to do updates for tags that are replaced with new tags.
  • GaryYegiazaryan
    Aug 18, 2022
    Another use case is if a display is referencing two different PI systems (by design). Example: A display has two trends with the data references below. \\old_piserver1\prefix1_sinusoid \\old_piserver2\prefix2_cdt158 I would like to be able to update the data references using wildcards like below: \\new_piserver1\prefix1* \\new_piserver2\prefix2* The current PI Vision Display Utility can only update all the tags to the same PI Server.
  • +1
