Created on Aug 18, 2022
PI Vision Display Utility: allow changes to the PI AF hierarchy when migrating displays
If we have AF content in a test AF environment, and then we build a PI Vision display on top of that in a test environment, we have a need to migrate the AF content to a different AF hierarchy in Production. The PI Vision Display Utility is clear in the Live Library documentation that this is not allowed at this time - you may only change AF server and/or the AF database name. We would like the ability to change AF hierarchy during a display migration as well.
  • Matt Voll
    Feb 22, 2023
    I believe there is an additional limitation here in that the asset the display is saved on, if that hierarchy structure is NOT IDENTICAL on the destination, it appears that the displays context switching capability is broken to the point of having to recreate every item on the display. The only way to keep the display from being broken is to make sure there is an identical hierarchy for at least the section the source display is saved on so that it can link up properly during the move. Then it can be changed
