180 VOTE
Status Completed
Created by MauricevB
Created on Aug 18, 2022
Copy tag name from PI-Vision display
Adding the option to copy the tag name of the selected item in a PI-Vision display to the Windows clipboard, so that that tag can easily be used in another application.
    Dec 15, 2025
    This item has been completed as part of the AVEVA PI Vision 2025 release. Watch an overview of the new features here.
    For additional information on AVEVA PI Vision 2025, please see the release notes here.
  • imuehlenhoff
    Dec 16, 2025
    Thank you :-)
    Oct 2, 2025
    We frequently Troubleshoot stale data on our screens or other issues that are signaled through the pi points or AF attributes that we put in our vision displays. the first step is to pull up the tag in smt or navigate to the AF attribute. a copy and paste feature would be amazing for both PI tags and AF attributes. Please make sure the AF attribute is easy to discover in AF. a whole server> element> attribute path should be able to be copied or discovered in the display. this helps with Legacy systems that were set up and for admins that are unfamiliar with their system.
  • Unknown Unknown
    Jun 6, 2025
    It baffles me that such a basic feature as the OP has put down here, requires such a detailed description and eleboration. Being unable to directly copy a PI tag from an attribute in display to the clip board in order to use it outside PI Vision is a massive flaw in basic design.
    Same goes for something so straightforward as colorizing text which is deemed impossible due to the very limited font options that PI Vision offers.
    Just do it. Why does this need to take almost 3 years to implement?
    Here on this production site everybody still favors Processbook over Vision for many reasons and this is just one of them ..
  • Max Chung
    May 13, 2025
    Our users rely on traditional PI tag names (not AF attribute names) when interacting with process data, as these are the identifiers they've consistently used across all the PI ProcessBook displays we've developed over the years. After migrating those displays to PI Vision, users now navigate our plant data by trending process variables. When deeper analysis is needed, they typically copy the tag name into PI DataLink to retrieve more detailed information.
    In PI Vision 2022, copying tag names directly from the interface was straightforward and supported this workflow seamlessly. However, that functionality appears to be missing or restricted in the current version. From a usability standpoint, this is unexpected—virtually every modern search or visualization tool allows users to copy text elements easily. PI Vision serves as a key search and discovery tool for our operations data, so limiting the ability to copy tag names reduces its effectiveness.
  • Jeffrey Totton
    Feb 25, 2025
    1. What specific problem are you trying to solve with this enhancement?
      1. When viewing PI Vision dashboards it can be difficult to determine the actual instrument Engineer Tag associated with the data you are viewing. This becomes even more difficult when viewing data that has been mapped to PI AF attributes.
    2. How would you like this feature to work?
      1. Add functionality to open and see information about the attribute or PI Tag when right clicking. When you right click on a PI tag in a display currently the option exists to "Add Selection to Ad Hoc". It would best if an additional option was added something like "See Selection Properties". Included in the properties would be the properties on the PI TAG which includes the Engineering Tag/Instrument Tag.
    3. Who will benefit the most from this enhancement?
      1. Anyone using the PI Vision screens to monitor equipment or a system that sees an issue would quickly be able to determine the source instrument for the data and take action. Currently we need to go through several steps to determine the instrument the PI Tag belongs to.
    Feb 24, 2025
    Greetings!
    One of the most frequent request we get during daily support of our users is "how can I copy this tag to my excel spread sheet". They see some interesting piece of information and want to get some values in PI datalink but there are no convinient way to simply copy and past needed tagname.
    This is not that big of a deal but it's about daily tasks users have with the data
    1. How would you like this feature to work?
    Context menu would be nice or anything that would be fast and simple
    1. Who will benefit the most from this enhancement?
    Regular users. From what I see all pi users that remebers PI ProcessBook admit that PIVision is not just a step but huge leap forward in usability, however they got used to copy tags from their displays and it will help them a lot
    Regards,
    Oleksii
  • Carl In Scotland
    Feb 21, 2025
    1 What specific problem are you trying to solve with this enhancement?
    Nurlyzhan Kumar below has already explained well – it’s too hard to copy information on the display to clipboard, all the workrounds are slow, error prone and come with risk of “damaging” the display (as you need to put into edit mode)
    2 How would you like this feature to work?
    User right clicks on an element e.g. a numeric value, multistate, or trend line in a graph or a tag listed in search and right clicks at this point there should be a context sensitive menu The Top option should be “Quick Copy Tag Name” this will put the tag name or AF element name on the clipboard. Below it should be a “More Copy Options >>>” sub menu. The options for the sub menu should be
    • Copy Row – this will copy Tagname, descriptor, Engineering Units to clipboard (Procesbook used to have this feature)
    • Copy Value – Latest Value, as displayed on the element, is copied to clipboard ie.. if the display is not in real time and has a time range from some days back it should be this value used.
    • Copy Timestamp / Value – as above but both the value and timestamp are copied to the clipboard
    Where more than one piece of information is pushed to the clipboard is should be “tabular” such that it can be pasted into e.g. Excel and the information goes into different cells.
    Users can already select multiple element with CTRL-Click (e.g. for Ad-Hoc trends), if multiple elements are selected when right clicking on the last one the same menus should appear and when pushing to clipboard the individual elements are separate rows in the “tabular data”
    3 Who will benefit the most from this enhancement?
    All users, everyone needs to share a tag name from time to time!
  • Nurlyzhan Kumar
    Feb 21, 2025
    Hello,
      We are trying to eliminate the manual, multi-step process required to capture a tag name. This inefficiency not only slows down our workflow but also increases the risk of transcription errors, which can be a hassle during troubleshooting or reporting.
      The problem:
      Currently, copying a tag name in PI Vision is quite clunky. I often have to either hover over a tag value and wait for about a second until the tag label appears - then manually note it down - or right-click, edit the tag, scroll down to the “label” option, and then copy it.
      We’d like to see a clear, "one click copy tag name” option either integrated into a right-click context menu or as a dedicated button on the display. When selected, the tag name should instantly be copied to the Windows clipboard, with a quick visual confirmation that it’s been copied. This would allow us to easily paste the tag name into other tools or documents without any extra steps.
      This feature would be a huge win for all PI Vision users - especially for process engineers, operators, and data analysts. It would save time, reduce errors, and streamline our workflows when we need to cross-reference or transfer tag names between different applications.
  • Gregor Emslie
    Jun 7, 2024
    As PI Vision usage in our company increases exponentially, the lack of very basic features such as this becomes more apparent and becomes a blocker to end users working efficiently and effectively in PI Vision.
  • Carl In Scotland
    Jun 7, 2024
    Frequently the first point of call to a query is a schematic in vision, whilst some analysis is done in vision we have various specialised tools where I need to enter the tag name. The ability to copy and paste into this or a spreadsheet, or even an email would save much time and reduce errors. PLEASE CONSIDER IT
  • MattBa
    Dec 11, 2023
    Couldnt agree more!
  • Justin Jackson
    Oct 13, 2023
    Agree with others that an option should be added when Right Click a value or Object on a PI Vision to display, there should be a "Copy Data Reference to Clipboard" option so can use the tag in another application such as PI Datalink. This would be a very useful and be a lot more user friendly then the current option of screen shoting the tag reference when hover over it or trying to search through an export if use the "Save as CSV" option.
  • Kenneth Barber
    Aug 18, 2022
    Related: https://feedback.osisoft.com/forums/320517-pi-vision/suggestions/20306590-ability-to-copy-and-paste-data-text-from-display-t
  • Dmitriy Aliev
    Aug 18, 2022
    It will be a very useful feature!
  • jrro
    Aug 18, 2022
    also the option to copy the latest value from a PI Vision trend to the clipboard would be useful.
  • A.Roomi
    Aug 18, 2022
    It will be usful feature if the tag in the display by right clicking on the tag have the option to copy to clipboard.
  • Dmytro Aliiev
    Aug 18, 2022
    Good afternoon Colleagues, This question is very relevant today. Please add this feature to the next version of PI Vision. Have a nice day.
  • +81
8 MERGED
Ability to easily copy paste PI Tag
Merged
Previously, in PI Processbook, PI Tagging can be easily copy paste at edit windows. Currently, its quite tricky to copy paste the tagging, you need to copy from the name of the tagging, if the name changed, the steps even troublesome. Propose to e...
Guest almost 2 years ago in AVEVA™ PI Vision™ / Sharing & Collaboration 0 Completed
10 MERGED
Copy and paste PI tags
Merged
Would be nice to be able to copy and paste PI tags into an excel sheet. That way we can us the pi data link in excel to pull data into the excel sheet. Whether it be from a certain point in time or to do live data. Having to type individual tags o...
Guest about 2 years ago in AVEVA™ PI Vision™ / User Experience 0 Completed
6 MERGED
Ability to copy Text, especially PI Tags from trends and displays to be used elsewhere
Merged
right now the only way to copy text is to go to the configure trend page and copy it from there, which is very tedious when you want to quickly copy to add to, say, datalink
france Gabara about 3 years ago in AVEVA™ PI Vision™ / User Experience 1 Completed
