111 VOTE
Created on Aug 18, 2022
Easily choose between AF attribute name and actual PI tag name
When creating a display using attributes (i.e. - Agitator Speed), I would like to be able to easily toggle between the name and the actual tag ID. I have access to PI System Explorer, so I can go and find it, but my end users do not and in some instances would like to display the actual tag and not the attribute name.
  • FranzK
    Sep 8, 2023
    As also shown for example in PIVISION-I-525, PIVISION-I-1717 and PIVISION-I-138, it's important for so many users to see the corresponding tagname to an attribute. This should be comfortable for the user and included in the system (no workarround with special configurations on AF side).
  • MaxWör
    Oct 25, 2022
    The PI point name is based on the PLC tag and offers the operator an indispensable connection between the process and the PI.
    A solution such as manually editing the AF attribute descriptor or extending it with the PI point name is not acceptable, requires a great deal of effort and is prone to errors, even when using the PI Builder AddIn.
    It would be good if something would move on this point, urgently needed for user acceptance!
  • Kelsey Bobeck
    Aug 18, 2022
    This would be very helpful. We will have control engineers accessing the system and they want to see tag names (e.g., TI202), because that's how it's shown in the DCS. However, managers and others who don't interact with the system as often want to see the attribute name (e.g., Boiloff Gas Temp), because the tag name means nothing to them.
    Aug 18, 2022
    Some operators are more familiar with PI tag names. Even if the PI Vision display is all AF based and using contextualizing navigation, the end user would like to have the option of using PI tag names instead of the AF attribute name, when the latter is a PIPoint DR. Would like to be able to quickly toggle from one to the other client side (from a button menu on the menu top display "Show PI Tags" or "Show AF Attribute Name".
  • ehoffman
    Aug 18, 2022
    It would be nice to see the PI point that an attribute is mapped to in PI Vision. Currently we have to look this up in either Process Book or Data link. It would be nice to have a one stop shop for this. Also it would be nice to configure PI Tag trends so that you could see the Tag description instead of the tag name or both.
  • Dave Tayler
    Aug 18, 2022
    Right click -> format trend Check box to display tag name instead of attribute name.
    Aug 18, 2022
    Having placed a Value symbol for an attribute in a display, under Format Value -> Visibility I can choose to have the Label changed to the tag's description, but I can't choose to have the underlying tag name itself as the label. This seems to be a pretty easy thing to add and would be much appreciated.
    Aug 18, 2022
    In PI Vision under the plot Trend Options, have the ability to assign the PI Tag Name for display in the legend. Optionally, show the server name as this can make the legend name long when displayed. The reason for this request is the plotted data is normally a PI tag value and this will make plot line identification easier.
    Aug 18, 2022
    This feature is very important for us as well. We are using PI Vision alongside our control system and it is vital that we can toggle/scroll over/tool tip to see the PI tag name so the control room operator can reference this in the control system before taking action.
    Aug 18, 2022
    Many people have requested this from me. Our attribute names are very easy to read but people want to see the PI tag names instead because that is how it's documented in other systems.
  • andre.moreira1
    Aug 18, 2022
    Ideally, this feature would be added to PI Vision. A substitution parameter option to extract the PI Point would also help. Would make it easier to build out with child attributes in AF, instead of using the TagName function for AF Analysis. But, as others pointed out, having this information easily available in PI Vision is preferred, since most users typically only have access to Vision. An extra Visibility item in the Value symbol would do the trick, or at least the PI Point name in the floating box that appers when placing the mouse over an object.
  • +11
