Status Completed
Categories Authoring Displays
Group Symbols and Objects on a Display
Be able to group and ungroup objects on a display, similar to PowerPoint.
    The PI Vision development team has completed work on mutliple symbol selection and grouping in PI Vision 2017. In design mode, you can click and drag to select multiple symbols on a display and then group them so they can be moved and copied together. Upgrade to PI Vision 2017 to take advantage of this and other new features. You can read about the key new features in PI Vision 2017 in our release announcement here: https://techsupport.osisoft.com/Troubleshooting/Releases/RL01216.
  • Stuart Godwin
    Nov 12, 2025
    This is pretty crude, barely qualifies as implemented.
    You can't create a group select an additional item add it to the group, or ungroup-> regroup to create a larger group with something you forgot. You have to ungroup, select the extra item then regroup, and if the extra item is a group then you are out of luck. you select every individual thing, which is probably why you grouped it in the first place. What I'm sure most people want is the program remembers the group, and likely the order you grouped it in, so you can group 2 already grouped bundles, then ungroup and still have your 2 bundles, just separate.
    It would also be wonderful to be able to resize the group, that way when the page doesn't fit nicely on the control room monitor, I could group everything, resize the whole group then when it is opened next time it will be the correct size instead of having to resize it every time.
    As it stands generally, I am better off selecting multiple symbols then copying or moving them ungrouped. There are as many drawbacks with grouped items as advantages to grouping
    Option to group or un-group objects in your drawing in coresight
